No need to tape it up. Pour some water in there, you'll see a drain right out the bottom. Only problem would be if he didn't replace the two pieces of "painted" tape on the inside of the tub, or at least secure the inner tub access holes with Gorilla Tape, etc.
Why wouldn’t evo extend the hinge mounting surface to cover the opening. Regardless if it drains that is just a poor design. It wouldn’t add that much cost to make the base of the hinge bigger to cover the opening.
For those of you guys with this carrier, Where did you find the small torx bit for the back up camera to get the plug out? (T-8 I believe)
I can’t seem to find one anywhere! Looking for local stores since Amazon is delaying all their delivery times.
I had one in my set, but you can check at HD or Lowe’s too. My set is from Lowe’s.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I got the three piece set from Harbor Freight, small fold out set. One is SAE hex(Allen), one is metric hex, and one is torx.
I think Auto Zone has the same set, just a couple of dollars more.
I threw a picture of a similar set on Amazon for reference
Check this page and one or two pages past for how I was able to "fix" the problem with how EVO does the brake light and camera.
https://wayalife.com/showthread.php/56685-The-rise-of-Olaf-The-JL/page6
Do you need to lift it to close it again? After running mine for a few hundred miles I had to readjust it, as it made a noise when opening (clunk) and I had to lift it close it. Now it opens and closes just like when it was new.
I can close it without lifting, but it just seems to be a little louder than stock unlatching when I first open.
Did you adjust it at the exterior hinges or on the inside ones?
I just rewatched Eddie’s video and it sounds about like his did when he opens/shuts it at the end
I may run it for a little while and see how it does. I’m to tired to pull that tire off again today.
Both, as well as 2 shims on the lower pivot mount (inner bracket).
