Didn't like the gap between my Oracal tail lights and the bed. So i picked up some rubber seals to go around the tails. I used these from Amazon.
Without seals:
with seal on:
I took the pic before tightening it all the way down.
That looks much better.
I have a set, installed one and took it off immediately because of the gap, will order the same trim and install them again.
The tweaked bumper from last weekend. New bumper arrived today. Used a little red loctite also. Can you believe that shit. Haha added a daytime pic. Turned out well but need to trim up the rear rock sliders to put them back on.
Got new KO3s for the wife’s Grand Cherokee. Upgraded from 245/65-R17 KO2
to 265/70-R17 KO3
The larger tires fill the wheel wells nicely without rubbing. Drove the GC down to Montrose Colorado to pick up a set of Best Top Element doors for the Wrangler. Smooth ride on the highway. I’m thinking of taking a detour through Moab on my way home!
Because the factory rock rails have a bracket welded on that bolts to the inside of the stock steel bumper I had to get out the grinder and cut the welds off. Smoothed it out and hit it with a couple coats of flat black and bolted them back on. Didn't want to give up the extra protection.
Changed batteries in my wrangler. Bolt sheared in aux battery box. So had to relocate it. Then found out after spending $400 in batteries my alternator was bad.
I totally got rid of that demon aux battery. Connected the + to the positive terminal! On main battery, and left - terminal alone.
Went and got a champion H7 battery and have had no issues in 4 months...
