ooooo shiney! :cheesy:
Thanks Sutten!
Tig- what is your dad using for a filter? Does he have a return line from the filter to the york for the oil? What is he using for oil? He could try gear oil if he is losing that much. Yorks are super easy to keep oiled, just listen to them, they will tell you when they need oil.
Tig- Yorks have a bolt on the side that can be used for oil return- I know it is hard to see in this pic, but there a fitting in the side of the york with a hose going to the drain output on my filter with a valve, I simply open the valve and run the york for 5 seconds to return any captured oil back to the york. I so the same for adding any oil, but I've only added oil once in the last year. I had this setup on my tj
Filter
Who doesn't love Bacon?
Bacon duct tape, lip balm, soap, bandages
