Just wanted to make a quick addition to this writeup after finishing the install on my 2014. First off as someone mentioned earlier I found it nearly impossible to install the mounting bracket and then the compressor. I ended up removing the bracket, mounting the compressor to it, and then bolting them up as a single unit.
Second, I used the Rugged Ridge a pillar switch panel for my install rather than the Daystar. Several people have mentioned they had a difficult time locating a place to connect the blue/white wire. Rather than attempt to run a wire over to the window switch area, I connected it in the drivers door wire harness to an orange/grey wire. Seems to be working well.
That is all. Hopefully it helps someone out.
