JeepinLife
Getting a popping/ clicking noise from what sounds like the front end. Still does it with the front drive shaft removed. Possible front u joints?
Control arm bolts torqued? I have one loose and it clunked.
yup. most like the axle shaft u joints. i would look at them now before it blows up on the trail like mine did
Only notice it in a turn? Would that be a sign still
Could be. You will have body roll in a turn which could cause it. Do you hear it when you hit a bump?
I had similar sounds, turned out it was my upper control arms beeded to be re torqued and the front trac bar. Just my 2 cents
Nope really have only noticed it when going slow in a turn.
As mentioned, most likely axle shaft u-joint(s).
Yea I greased them up and it stopped... Now that's obviously only going to be temporary right?
You took them apart and put grease on the needle bearings or sprayed pb blaster over them?
This. The same thing happened to me recently. I would hear clicking only when I turned left, and from the right side. It was a very distince clicking. I took it in, explained to them the progression of the clicking and how it got louder over time. It was replaced under warranty. Once replaced, the clicking stopped all together.
