JK owners running EVO DTD system
Do you adjust the silver cross over rings on all the coilovers ?
The cross over rings are the silver rings that are threaded on the shock body. You can adjust them up or down to determine when the spring hits them and transitions from the initial spring rate to the bottom spring rate.
Or do you just simply install install the coilovers as they come shipped from EVO?
Second question.
Do you adjust the compression tubes and rebound tubes or leave it as stock from factory?
Since we do not have real estate to mount addtional King Bump stops how do you adjust the rebound compresssion tube to work as bump stop?
Any input would be great especially from EVO if they can?
Second question.
