Why Teraflex, a suspension company and not an axle company?
As for your question, I'd do the front first. Swaping to a bigger housing won't stress the other. Just make sure your gear ratio is the same in both.
I would love the prorock 60 but the crd 60 is a little more affordable. A concern I have is saving a little now would cost in the long run.
There's a reason it's a little more affordable. Just saying.
What tire size are you looking to run?
I am eventually going to upgrade to the crd 60 front and rear. But was wondering should I do the front or rear first. Which is under more stress? I think the front should be first just because it's a Dana 30.
As others have asked, how big of a tire are you hoping to run and, do you really think you need something like a 60 in your neck of the woods? As mentioned, there's a reason why Chinese made axles cost less.
37's but like the peace of mind a Dana 60 would offer.
Being out in Yonkers, NY, exactly what trails are you planning on running and how often that would require that kind of peace of mind? And, to that point, you have a lot more faith than I would in a chinese made 60. Of course, I'm just a mall crawler who runs his 37's on a ProRock 44 so, don't mind me. :crazyeyes:
I'm not running anything crazy right now as my build been a little slow. But by March I plan on having a 4inch Evo long arm king shocks 37's and at least have changed out one of my axles.
I understand the piece of mind aspect. But to put things in perspective - member Noroad (and others but I don't know their setups) just finished a trek from MA to CA - wheeled the Rubicon and is driving back all on a Dana30, with 4.88 gears and no front locker with 37s.
Save your money and just get a front PR44. And if you break your rear get either a trail60 or a PR60 for about the same as a set of the CRD60s. Without the "made in China" stamp.
Dynatrac axles are the top of the line best axle you can buy for your JK. If it is absolutely out of the question to spend that kind of money, I'd look at the Mopar/Spicer Ultimate Dana 60 axles. Same price range as the Teraflex axles, but you get full float 8 lug axles, 1 1/2" 35 spline 4340 chromoly shafts, 1550 u joints on the front axle, larger diameter tubes, and a 10" ring gear up front. Teraflex are semi float rear, and with their track record on quality I couldn't recommend them.I would love the prorock 60 but the crd 60 is a little more affordable. A concern I have is saving a little now would cost in the long run.
I've seen that. He launched it over 90 feet. I guess if you plan to do that sort of stuff Dynatrac's most stout axles or even something stronger ( if there is such a thing) are what you'd need to look at.Ask David Bruton what he thinks of the mopar axles. <img src="http://wayalife.com/attachment.php?attachmentid=155089"/>
