Perfect. Ill check that out. Any idea if that K1A works with any model firestik?Fire stick K1A quick release works well.
I've used it for years.
Thanks. I was figuring i would need to do that. Im gonna have to redo it all soon anyway with an aftermatket carrier.I use the firestik quick disconnect with my garage too. Works perfect. If you get it, I suggest you retune your CB with it on there.
Edit: im sure google will tell me that. Lol. That was a laziness based question...
Any using this or know which one works well? Seems my new garage door is shorter than my current one so the rig wont fit with the firestik connnected.
Im goona have to look agai. Pulled in at new house and the wife yelled stop the folded my antenna down saying it wasnt gonna fit. She coulda been totally wrong so im gonna try and check myself todaySeems to me like you need to ajust your door, opening is the same sise
Yeah, don't ever trust the wife on knowing if it will fit or not. Lol.
I feel like there's a "that's what she said" joke somewhere in this comment.
My experience (with the Quick Disconnect that is) has been pretty bad. I had read that they come apart after a while. My situation was that I could not get a good ground out of the thing, and such, my SWR was very high. I also understood that the quick disconnect will accumulate water and then eventually rust. The old ones used to be really good, but the new ones are not made as well (read Chinese) and failed after a short while.
I simply unscrew my Firestik II from the mount when I want to park it inside. It is easy and I get a much better transmission with a SWR of almost 1.1!!
As for the wife, super happy with her.
