Roof rack
NCAJeep
What’s everyone’s favorite roof rack solution without the hard top on? The JKU I bought has a rhino rack on the hard top but I’m looking for something for the factory roll cage
I don't know anyone here that still runs a rack at all, but if you want one that is still in place topless or not I like the Gobi Stealth Rack.
Yaaa I really don’t like the looks of the exoskeleton deal. What’s the conventional wisdom for a 3-4 day rubicon run with a wife and two kids. I’ve got an American adventure lab cargo tray on order just looking at options if I need more space.
Throw one of these rear storage trays in
Other than that not much more you can do in a jeep
Right on. Wasn’t sure if there was a generally recommended solution but this makes sense.
I get what you’re saying but I didn’t ask how much to pack.
I’m hoping to not need a roof rack but I also like to plan ahead and explore options. Thanks for your insight though!
I run a rhino rack platform with the Maximus-3 roll bar mounting system, have to drill through top but you can technically run it with or without the hard top. Has high load rating as well as it mounts to the roll bar. Maybe you can just get the Maximus mounts being you already have the platform
Leave the kids behind, remove the rear seats, and install a full Goose Gear setup with slide out drawers, a fridge, and a folding table on the tailgate. 😄
Maybe
Maybe if I make it to retirement age but that’s not gonna happen now. If I’m understanding correctly I shouldn’t need to carry so much spare parts and/or gear that I’d need a rack.
Maybe
how many spare parts/type are you taking? are you going with a group?
easy pedal work and picking good lines should keep you from breaking things, of course anything is possible but a precheck on the most likely to fail components would be what I would do if I didn't know what's been done to the Jeep.
Fluid changes (diffs, transfer case etc...), check hubs and u-joints, aftermarket drives shafts or stock?
Maybe
It is a sort of Catch-22 situation that the heavier you make you Jeep, the more likely it is to have mechanical failure, or get stuck. Modern jeeps are so complex that many failures are not fixable outside of a dealership (or similar). There is an argument for bringing spares for mechanical or electrical parts which are most likely to fail on the trail, and spare fluids. But there is only so much you can do, and Jeeps are not good at carrying a lot of weight or "stuff" in general.
If you are traveling with others, it may be that there is a skilled mechanic among them, but if there is not, then burdening the Jeep with many spare parts (many of which may be expensive or difficult to buy or replace under normal conditions) just in case they may fail does not make sense.
It is important to pack tow straps, jacks, battery jump pack, and whatever else is needed to get your Jeep to where a tow truck is willing to pick it up if possible. Normal towing like AAA is only willing to show up on normal roads, and off-road recovery can be very expensive.
Make sure that you have a means to call for help when there is no cell signal. Something like Garmin InReach is a good idea. If there is risk, then find someone else with a different vehicle to travel with you.
Backpackers are able to live for a week using what they are able to carry on their back. Dialing back on how you camp, and avoiding the modern overloaded "overland" approach, should allow a family of four to live out of a Jeep for st least as long as backpackers do. Use a ground tent, sleeping bags, camp stove, freeze-dried camp meals etc. Carry a lot of water, and in multiple containers. Water may be the most important thing that you carry.
What Jeeep said above...
Look, It's really easy to talk yourself into needing way more shit than you actually do. Unless you're going way into the back country or some serious rock crawling to get there, standard safety gear is gonna be enough. Unless you drive like a maniac, your Jeep isn't going to start shedding and breaking parts once you get on the trail. Pack fluids, u-joints, tire patch kit, good tool kit, compressor & you should be good. Unless you drag a trailer around
Not a direct response to the use case but for everyone who is too snooty to slap a rack on their jeep, kindly piss off. Lol...
I have a cheap, rain gutter mounted rack. I use it to transport two 5+ ft diameter dip nets with 30 ft (break down to 10 ft lengths) poles to my preferred dipnet location, which involves a 2 hour drive followed by 3 miles down a deep, sandy beach that requires I air down to not get stuck.
For my needs, a cheap roof rack is ideal. I just make sure to remove it as soon as I get home so hopefully nobody sees it on my jeep.
