Jeepin with Judd
Joey1313
I am going to meet my father at Jeepin with Judd the weekend of February 20. Around Orlando FL area. Is anyone going or have they gone before? Hoping it will be a fun event.
Usually do Octoberfest but haven't done the Jeeping With Judd event. That said it is a huge event and usually pretty crowded from some of the videos I've seen over the years. Should have good vendor support.
My dad went last year and enjoyed it. He is getting up there in years so I want to spend as time as I can enjoying life with him and mom. It's a long trip but should be a good time.
They require a fire extinguisher so I ordered the element one. Honestly will probably order a couple more. Installed with zip ties driver side rear.
It works kinda like a flare. Pull the cap and strike it to start it and then point at fire.
They are kind of expensive, but the sparkler only works for the number of seconds indicated on the side so you would need to get on the fire right away, and get close to it.
I have an Element, but have looked at "Purple K" traditional extinguishers (does not destroy the wiring), and even Halon/HalGuard. To me, HalGuard seems best.
I have thought about using a system like I had in the racecar but it's overkill. Something similar to this:
That is an interesting idea, but complex and expensive. If a fire starts in the engine bay, the Jeep could be totalled in just a minute, or a few minutes. A fire control system which automatically responds almost instaneously would be useful.
A general purpose fire extinguisher is handy for any small fire which starts in the periphery of the Jeep.
They have automated systems but they are expensive. These are actually pretty simple. Manually activated but have nozzles under the hood and on the interior. You or a passenger can activate without having to get out of vehicle and also put a release handle on the cowl and someone outside the vehicle can release it. Hmmmm, maybe later in the year i'll mount one up.....I think I have enough parts left over to make a decent system. They do make a mess though. Might need to check out more modern setups.
That's a lot of overthinking, do regular maintenance and pay attention to the leaks and you have will likely never use the fire extinguisher.
I keep a regular ABC and an Element in the Jeep, ABC for grass fires if needed and the element for engine bay, I've replaced the ABC because of age but have never used either.
True...i've never needed one before. I only put the Element in because they require an extinguisher for this event. I may put a regular ABC later for giggles but I almost never pass up a rabbit hole to go down LMAO
I think the rabbit hole is every old man's demon, I've left mine in the shed for my daughter to deal with after I'm gone lol
Having a blast here and learning a ton about my Gladiator and my ability.
Many hundreds of Jeeps today but the wait times are very minimal. I did the 2 advanced trails and then 1 moderate trail. Picked a questionable line on the hardest trail and 2 wheeled it almost onto my lid but it settled on all 4 without rolling over. Thankful to have not totaled it. Did gently rub a tree later in the day with driver front fender. Will need to remove fender and replace plastic clips?
I shot some videos but will need to edit before posting.
Going to knock out the other moderate trails tomorrow and then the stock trails Sunday.
Also Joey1313 remember the SAVE Expo is in Starke, Fl next weekend if you are up that way. Might go up Saturday, camp, and roll back to the Tampa Bay area on Sun.
I think my Dad is going to an event next weekend. I'll be back home in N. GA on Monday. Lots of fun to be had in FL through.
Had a tiny bit of rub on front fender liners at front edge. Didn't think with 4.5 lift and 37s it would rub any. Watched Eddie's fender chop video. Rugged Ridge out of the DRL kits. Rugged Ridge getting on my last nerve. Don't have the bed cover I ordered and the cb/am/radio mount is now discontinued. Bunch of bums....just kidding 😂 😂
