Close
Page 20 of 20 FirstFirst ... 10181920
Results 191 to 199 of 199
  1. #191
    Been Around the Block Kruebicon's Avatar
    Aug 2016
    Carthage Texas
    444
    Id drain then dexcool if it were me,save you 50$
    If your not living and having fun,your dead already
  2. #192
    Been Around the Block Frydaddy's Avatar
    Feb 2016
    Phoenix
    263
    Quote Originally Posted by Kruebicon View Post
    There could be more to it though. If you are going for a full drain, you cant. short of pulling freeze plugs, even pulling the lower coolant hose will only remove half of the coolant.
    If you want to start fresh, you have to flush it multiple times to get all the old coolant out of it. Use distilled water and run it up to temperature so the thermostat opens as well. Some may also run their heater as well.
  3. #193
    Aug 2016
    Carthage Texas
    444
    Your rite
  4. #194
    Oct 2014
    North Richland Hills, TX
    413
    Had a bad radiator in my 14 and the dealership replaced it. It tells me to use item # 68163849AB and this is what the same dealership sold me several months back when I was low on coolant. Fast forward to the radiator replacement and they put in 68163848AB. Not sure the difference between 49AB and 48AB but they seem to both be OAT. Looks like they might just be UOM sold.
    Can anyone verify this for me?
  5. #195
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    13,067
    Quote Originally Posted by mastrcruse View Post
    I would check with the parts department at the dealer. A lot of times, parts can be updated and the part number will be superseded by another number.
  6. #196
    Oct 2014
    413
    Ah good idea...didn't think of that. During a search, both seem to come up as OAT.
  7. #197
    Feb 2016
    Phoenix
    263
    The 48AB is full concentrate, the 49AB is 50/50 premix.
    If you even need to buy more, get the full concentrate and use distilled water from any grocery store of your choosing.
  8. #198
    Oct 2014
    413
    Quote Originally Posted by Frydaddy View Post
    Thanks...appreciate it.
  9. #199
    Fresh Catch ELBRAVO's Avatar
    Jan 2014
    MIAMI FLORIDA
    29
    Great Post! I own a 2013 JK 10A Rubicon. I went to my dealer's part department and put in my VIN number to make sure it was the correct part number. They may charge you more than expected but it is worth to have peace of mind.
    I utilize the (left over fluid) to maintain the proper level. I also utilized a Silver permanent marker and put the OAT reference / reminder on the top of my radiator.
    Stay safe,
