Welcome to the WAYALIFE.com : More than just a Jeep - It's a way of life!.
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Oct 2011
    Laguna Niguel, CA
    9,882
    MagLite Flashlight Seat Mount Write-Up
    Because you never know when you're gonna need a little extra light, I like to carry a good MagLite flashlight with me in my JK. Unfortunately, there really aren't a whole lot of convenient places that you can store one without it rolling around while you drive and driving you nuts. And, that's why I decided to secure mine with a mount. Fortunately, MagLite sells a basic wall mounting kit that you can buy for cheap at your local hardware store and, it can be installed in minutes. Here is a quick write-up I did to show you how easy it is to install.
    What you'll need:
    • MagLite Mount Bracket Kit
    • Hand Drill
    • Small Metal Drilling Bits
    • Center Punch
    • Phillips Screwdriver
    • Self-Tapping Bolt
    • 5/16" Socket
    • Ratchet
    Here's a shot of the MagLite mounting kit.
    Using one of the MagLite mounting brackets as a template and mark the points where you will need to drill on your driver side seat rail with a center punch.
    Drill the mounting holes into your seat rail as shown. If I recall, I used a 1/16" drill bit.
    To make this install easier, I used a self-tapping screw about the same size as the screws provided to thread the mouting holes. A 5/16" socket was needed for this job.
    Finally, I secured the mounting brackets to the driver side seat rail of my JK using the phillips screws provided.
    And that's all there is to it.
    Please let me know if you have any questions
  2. #2
    Fresh Catch
    Oct 2011
    Windsor, Ontario, Canada
    1
    Where do you get the brackets? I can't find them ANYWHERE
  3. #3
    Oct 2011
    Laguna Niguel, CA
    9,882
    Quote Originally Posted by 210GoldenEagle View Post
    i bought mine from a local True Value hardware store. i don't know what kind of hardware stores you have up in canada but, i would check there or anywhere MagLites are sold.
  4. #4
    Moderator
    Oct 2011
    Fresno, CA
    709
    I am going to do this pronto. Thanks for the write-up Eddie.
  5. #5
    Fresh Catch
    Nov 2011
    Springfield, MO
    1
    Are you using a 3-D Cell maglite?
  6. #6
    Oct 2011
    Laguna Niguel, CA
    9,882
    Quote Originally Posted by bradhilldesign View Post
    yes, a 3-D cell with LED
  7. #7
    Fresh Catch
    Nov 2011
    Maryland
    11
    I picked mine up from Walmart.
  8. #8
    Fresh Catch
    Oct 2011
    colorado
    13
    Great idea! Thanks
  9. #9
    Fresh Catch
    Oct 2011
    Rockville
    6
    Could you do the same thing with a 1lb Fire Ext?
  10. #10
    Fresh Catch
    Feb 2012
    Anchorage, Alaska
    16
    Definately doing this one! so simple, quick and easy!
Back to top
