GraniteCrystal build thread
GraniteCrystal
Maybe I'm just tightening it down too much? Noticed this geometry and wondering if it's made to bleed pressure and I'm just sealing it too tight. Going to experiment with that theory next and see if I can quantify how many turns to go so that it seals the liquid but not the vapor.
Also, note to self: pour gas into Jeep before attempting to re-seal the tiny hole you made by HOLDING A FLAME TO THE ROTOPAX to melt the plastic. Nearly blew myself up. Stupid. Stupid. Stupid.
JKbrick
Probably not thinking straight but I'm not sure what type of device would let the vapor out and not the liquid. In plumbing we use a mechanical fitting called an air admittance valve that lets air into a drain so it drains but doesn't let out sewer gas. Same theory as what you want when you are pouring so the can doesn't glug glug glug
cashin
The gas fumes in a empty rotopax will be more volatile than a full container.
Sent from my LG-P769 using WAYALIFE mobile app
GraniteCrystal
Got a new DIY project for you guys today: bottle opener.
After relocating my license plate, I wanted to replace the hole with one of these:
But they were no longer available. So I made my own!
The JKS relocation kit came with a small metal plate to cover the hole. I used that as my outline and it's a piece of the final assembly.
I then drew my design:
Time to start cutting!
Tried it out and the design evolved as I kept testing the fit.
Clamp them together for final cuts:
Bent by hand to same curvature:
Bent it outward:
Clamp and drill holes to match:
Spray painted:
I mounted it up and tried it out. Failure. I forgot about the bumper so the bottle had to invert to open. I tried with a Corona and ended with beer sprayed all over me.
So...bent it out in a new way.
And changed up the shape of the hole.
Here it is all done!
15 second video showing it work:
https://youtu.be/tcV-IpL3WnU
Napalm
Bent it outward:
Spray painted:
That's awesome! Great idea!
GraniteCrystal
Took Scout into Trail Jeeps this morning for the follow up diff oil change after 750 miles. All looked good. Oil was greenish and shiny. No metal chunks.
Also had them flex it out for the first time with 37s on there to check pinch seam, brake lines, fender rub, and sway bar. Everything passed with flying colors. I'm going to trim about 1/2" off the rear corner of the pinch seams in the rear wheel wells just to be safe, but nothing rubbed.
Stuffing up into the fenders. No rub with those lines I chose 👍
Sway bar not over rotated (sway bar still connected but it not going to droop significantly more such that it'd be close to over rotating)
GraniteCrystal
Doing more research on a new front bumper. I think I've narrowed it down to these two. I'm noticing lots of similarities between the different options (the new LoD is very similar to existing Crawler Conceptz and Poison Spyder bumpers), but each of these had something unique going for it the others didn't.
Option 1: LoD Destroyer Series - $687
Pros: same line as my Destroyer rear series bumper
http://lodoffroad.com/products/jeep...nt-bumpers/2007-2016-jk-destroyer-shorty.html
Option 2: Crawler Conceptz Ultra Series - $750
Pros: recessed winch
http://crawlerconceptz.com/index.php/ultra-series-jk-front-bumper-recessed-winch-mount-bar-tabs.html
Thoughts?
Ddays
Personally I like the recessed winch better, but one detail to ask either company: Do you have to remove the winch in order to remove the grille?
With my FMF Apex I have to take the winch out first. I really like the bumper but having to do this first is a pain in the ass. Looks like possibly the CC
version is the same way? Worth asking.
Edit: Talking specifically about the Warn Zeon series. Can't speak towards any other make or models.
GraniteCrystal
You have to remove the winch to remove the grille? How did they even make it like that? Sounds like a big pain the butt.
Ddays
It's because the winch is so far back in the bumper you can't pull the grille forward enough to get it loose. The winch almost touches the grill. I suppose if you don't care about paint you could work it loose but
its easier to just take the damn thing out.
GraniteCrystal
I called. They haven't tried but didn't think it'd pose an issue. Not quite sure what to do with that.
Ddays
Here's a couple pics to show how close it is. It's almost touching the winch but not quite. The problem is that you can't easily pop the bottom pins that hold the bottom of the grille out.
