The Ultimate TRUE TIRE SIZE Database
Flat Top
Nitto Trail Grappler 23,000 miles
37x12.5x17
35.25 in
I'm very interested to see how my wear compares to others.
GoldenJK
Yep. My MTRs are wore our and cupped bad. Someone please post Nitto Grappler M/T in a 37x12.5R17. That's next if it fits in parking garage
jeff_in_rc
My tires
General Grabber Red Label at 30 psi
Stated size: 35 x 12.50 x 15
Actual size: 33 1/2 on the outer lug, 33 3/4 on the inner lug
Tire wear is 1,000 miles
2nd.gunman
This is great. I was just wondering the other day that if 35s generally measure at about 33" does that mean 37s measure at 35".
adamsnewone
Because ideally you would want your tires as flat as possible. But also, I think he is looking for an easy basis for everyone to go by and keep it uniform.
SilverBack
Just out of curiosity, does anyone have the mounted size of the Toyo Open Country AT II 285/75R17? Seriously looking into these..
Packers937
Went out and grabbed a pic for you. 285/75R17 Toyo Open Country ATII's at about 32 psi with ~300 miles on them. Sidewall says 34"x11.5". Looks like it sits at about 32.75"
WarriorJeep
1: General Grabber Red Letter
2: 35x12.50x17
3: 34 inches exactly (picture was taken at slight angle, checked all 4 tires same same) 3000 miles
notnalc68
That dude from Mississippi
Goodyear Wrangler Duratrac, LT285/75R16, 30 psi, passenger side rear. It was my spare and has less than 500 miles on it.
31 & 5/8"
Brod
Dose this mean if I understand correctly if I wanna run 37" tire I would actually need to get 40's but then I would need bigger axles but they are still only 37"
MR.Ty
Token East Coast Guy
No. In order to run 37s, you need to buy 37s. Everyone who provides size recommendations goes off of the side wall number. From suspension makers to trail recommendations.
