CJ buggy build
klungly
Took the seals of the axle shafts with a gear puller. 1477271369271.jpg I got a new yoke, but it wasn't long enough, I cut off what was needed from the old flange and welded it onto the new yoke. 1477271545210.jpg 1477271549907.jpg 1477271553394.jpg
klungly
Both kingpin kits came today, now I'm waiting on the lower bearing caps. I didn't think about them until I was figuring out how to put everything together. This is the first time working with kingpins so it's a learning process. 1477453296743.jpg
klungly
My locker showed up for the front axle. 1479355057736.jpg Enough heim joints for front and rear 4 link came today. 1479355239069.jpg getting all my parts ready for when we move into a house with a garage next month.
klungly
I took advantage of black Friday and ordered all the parts I need to build my suspension. The first box showed up a few days ago with all my mounting brackets. I have the Dom for my links, a tubing bender and hydraulic ram coming tomorrow. The adapter to make the bender air/hydraulic came as well. IMG_20161205_202644543.jpg
T_rav
I'm gearing up to build my own sliders. I'm really starting to wish I had a tubing bender. Can't wait to see that thing with some axles and a cage installed
klungly
IMG_20161208_210629394.jpg The first half of my control arm tubing came in today. 4' x 2" 250 wall tubing. Maybe a little too long. One of them is mocked up with the full length tube to be about 4.5' from hole center to center.
klungly
My tubing bender is all but done. Next is fabricating a stand for it IMG_20161220_182027447.jpg . I finally have a place to work on the CJ it self. As long as work at my job stays slow I'll be able to get tons of progress made. IMG_20161221_202636495.jpg .
T_rav
I think it'll be worth it. I'd like to see those rock sliders when they're done.
I've started building them but time is precious so it's a slow road. I found a friend that has a bender so hopefully next week I'll get my two bends done and I'll be able to get moving again. I plan on doing a write up once I'm finished with pics so I'll keep you posted.
klungly
I'm looking forward to seeing them.
