Close
Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 180
Thread: CJ buggy build
  1. #151
    Knows a Thing or Two 2Cross's Avatar
    Dec 2014
    Albuquerque, New Mexico
    830
    Quote Originally Posted by klungly View Post
    Cut some of the frame off, some more might need to go depending on where the new control arm brackets go. More of the tub is going to get cut as well I'm rethinking my transfer case, not sure I like how much it's clocked. I'm really thinking about springing for an atlas.
    Problem with the old CJs is they are so short.
    Another transfer case may not fit due to length issues and where your rear axle ends up. Atlas is nice and strong
    Also, where are you getting your fabrication parts?
    Willys / 1949 CJ3A
    Autumn Yellow
    2.2 Ecotec to th350
    HEMI / 2011 JKUR
    Sahara Tan
    UNNAMED / 2012 JKR
    Ruby Red
  2. #152
    Hooked klungly's Avatar
    Jun 2016
    poulsbo WA
    149
    Quote Originally Posted by BABOOZLE View Post
    Looks like I need to come over and grab some parts now.
    Grab as many as you want, I need more space in my garage.
  3. #153
    Knows a Thing or Two BABOOZLE's Avatar
    Apr 2015
    Washington
    560
    I'll swing by Tuesday.
  4. #154
    Jun 2016
    poulsbo WA
    149
    Quote Originally Posted by 2Cross View Post
    Unfortunately I chose one of the shortest CJs. I'm going to stretch the wheel base to 110", most if not all will be in the rear. I want the Atlas so it will raise my front yoke and give me more clearance for the belly skid plate and it's an Atlas.
    My trusses and brackets are form artec. My heim joints, control arm DOM and diff covers are from ruffstuff. My role cage DOM is from a local shop. All my axle parts have been from summit and Northridge.
  5. #155
    Jun 2016
    poulsbo WA
    149
    I cut up the old tub to take to the scrap yard and started to mock up the rear axle. IMG_20170109_190853603.jpgIMG_20170109_191025813.jpg
  6. #156
    Jun 2016
    poulsbo WA
    149
    Prepped the frame to accept tubing. Started to figure out the new roll cage.IMG_20170112_165233886.jpgIMG_20170112_171859483.jpgIMG_20170112_173842339.jpgIMG_20170112_180109044.jpg
  7. #157
    Dec 2014
    830
    You worried about that old frame holding up to the big axles and tires?
    I broke the frame on my old CJ5 in 1989. That metal has aged a bit since then
    Willys / 1949 CJ3A
    Autumn Yellow
    2.2 Ecotec to th350
    HEMI / 2011 JKUR
    Sahara Tan
    UNNAMED / 2012 JKR
    Ruby Red
  8. #158
    Jun 2016
    poulsbo WA
    149
    No, it's going to be a tube chassis with the frame as somewhere to start from. I'm using 2" X .120 wall DOM
  9. #159
    Dec 2014
    830
    Got it.
    I must have missed that
    Willys / 1949 CJ3A
    Autumn Yellow
    2.2 Ecotec to th350
    HEMI / 2011 JKUR
    Sahara Tan
    UNNAMED / 2012 JKR
    Ruby Red
  10. #160
    Jun 2016
    poulsbo WA
    149
    I bent the rear lower hoop.IMG_20170113_144438760.jpgIMG_20170113_151705867.jpgIMG_20170113_154611935.jpg. I need to get a more accurate angle finder. I was about a degree off o. The second bend. Pretty good for my first piece though.
