CJ buggy build
daddyusmaximus
I love newer and better suspension setups, but seeing that shot of the ass end coming off almost made me cry. I just love the old school look of a CJ5. Now there is one less...:eek:
klungly
Got some more work done tonight. Took the rear axle out. My garage keeps getting smaller. My goal is to be working on the new rear axle next week. I bought 50' of 2" .120" wall DOM today also. IMG_20170107_211716300.jpg IMG_20170107_215720574.jpg IMG_20170107_222731183.jpg IMG_20170107_225842720.jpg
klungly
Cut some of the frame off, some more might need to go depending on where the new control arm brackets go. More of the tub is going to get cut as well. IMG_20170108_162403401.jpg IMG_20170108_165055980.jpg . I'm rethinking my transfer case, not sure I like how much it's clocked. I'm really thinking about springing for an atlas.
2Cross
Cut some of the frame off, some more might need to go depending on where the new control arm brackets go. More of the tub is going to get cut as well I'm rethinking my transfer case, not sure I like how much it's clocked. I'm really thinking about springing for an atlas.
Problem with the old CJs is they are so short.
Another transfer case may not fit due to length issues and where your rear axle ends up. Atlas is nice and strong
Also, where are you getting your fabrication parts?
klungly
Unfortunately I chose one of the shortest CJs. I'm going to stretch the wheel base to 110", most if not all will be in the rear. I want the Atlas so it will raise my front yoke and give me more clearance for the belly skid plate and it's an Atlas.
My trusses and brackets are form artec. My heim joints, control arm DOM and diff covers are from ruffstuff. My role cage DOM is from a local shop. All my axle parts have been from summit and Northridge.
2Cross
You worried about that old frame holding up to the big axles and tires?
I broke the frame on my old CJ5 in 1989. That metal has aged a bit since then
klungly
I bent the rear lower hoop. IMG_20170113_144438760.jpg IMG_20170113_151705867.jpg IMG_20170113_154611935.jpg . I need to get a more accurate angle finder. I was about a degree off o. The second bend. Pretty good for my first piece though.
