Welcome to the WAYALIFE.com : More than just a Jeep - It's a way of life!.
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 76
  1. #51
    Fresh Catch
    Jan 2013
    Granbury, TX
    26
    Spidertrax Wheel Spacers Installation Write-Up
    I just finished installing my spacer but there is something I am concerned with. The rear driver side after taking the retainer clips off, the rotor would move left and right a small amount. The passenger side did not do this. Should I be concerned?
  2. #52
    Been Around the Block
    Nov 2012
    San Diego
    272
    I love the spacers easy to install once you get the clip removal down lol.
    2013 Commando Green JKR
    2.5" Rock Krawler Max Travel
  3. #53
    Fresh Catch
    Oct 2012
    Ontario
    15
    Quote Originally Posted by MikeD View Post
    I pretty much fit your description to a T. Love the look of the stock wheels and on a pretty sad budget haha! Very happy with my Spidertrax spacers. Budget for the build was roughly 2g, as business gets better so will th build.
    Do you have any lift?
  4. #54
    Feb 2013
    san diego
    197
    Tera flex wheel spacer??? Yeh or Nay???
  5. #55
    Nothing but a Thing
    Apr 2012
    Dayton OH, Orange County CA
    1,530
    Re: Spidertrax Wheel Spacers Installation Write-Up
    Quote Originally Posted by jkrossi View Post
    Dont know anything about teraflex spacers, BUT a spacer is a spacer is a spacer as long as its hub centric, not lug centric, and its not a pancake "gap maker" that only reuses what's left of your shortened lugs.
    Sent from a migrant connectivity device
    2013 Dune JKU Rubicon <-- Build Thread
    Installed: 35"Nitto Muds, LOD Sliders, DynoMax Comp Exhaust, EVO ProTek Skids, Fender Trim, EVO 1/4 Pounder and stinger, Warn 9.5ti, EVO C-Gussets, 1.5" Spidertrax Spacers, AEV Procal
    Needs Installed: Rock Krawler Front Lower CA's, EVO F&R Bolt-on King Coilovers, JKS Front Track Bar, OR-Fab Jerry Can Tire Carrier
    Looking to Buy:Drag Link Flip, 1350 Front DS, Rubicon front axle shafts, Sport Cage, Long Arm System, on-board air, Hydro steering
  6. #56
    Nothing but a Thing
    Oct 2012
    northern york county PA.
    1,936
    Quote Originally Posted by StrizzyChris View Post
    I don't know if its common or not but a buddy of mine bought some that I can't remember the name of, it was something generic though and two of the spacers had the studs pull out ? thats why i would spend more for a good name myself. but hay he said they were cheep.
  7. #57
    Feb 2013
    san diego
    197
    Yeah they are hub centric I wouldn't dare mess with any other design. Well ill give them a try and if my wheels fall off ill let you all know.
  8. #58
    Nothing but a Thing
    Apr 2012
    1,530
    for off-road use and professional drivers only!
  9. #59
    Knows a Thing or Two
    Feb 2013
    Page, AZ
    822
    I installed 1.5" Spyder Trax. The Jeeps steering radius is so amazing that I still rub. I actually rub the lower control arms. I found a solution to the issue on JK-Forum. A 3/8 washer behind the steering stop. The solution is easy and safe. Don't tell my wife though. Daddy needs new wheels! Lol
    Lock Down or Get Locked Up
  10. #60
    Nothing but a Thing
    Oct 2012
    1,936
    Quote Originally Posted by Philip *AZ* View Post
    What size tires do you have?
    Sent from my PC36100 using WAYALIFE mobile app
Tags for this Thread
Back to top
