The long and slow build of "................"
Ddays
I didn't trim mine. The look didn't bother me enough to trim the ends.
This was before I put the EVO fascia on
10abadilla/jk
It actually does not look bad. I was concerned it would be sunk in to far and the d- rings would have an issue hitting the frame hole. But it looks good. Thank you for picture. I think that is what I'm going to go with. Seems like a great option.
Sent from my LG-H900 using WAYALIFE mobile app
10abadilla/jk
Got the replacement track bar in today. 20170322_181731.jpg 20170322_181740.jpg 20170322_181746.jpg
It now has a lot more clearance compared to the other one. I have yet to do any flex test. Maybe later tonight. One concern I do have now is the steering wheel judder is back. Any ideas what it could be?
10abadilla/jk
What did they do different with the track bar? Rebend it?
No they sent me a while new one with a slightly different bend bending away from the diff
First track bar
Replacement track bar
The judder is not consistent either. And it does not happen when I hit a bump or pot hole like ball joint might do. And it seems to only happen between like 30-60 slightly then fades away. Almost like toe in/out is off or something with the alignment. I could be wrong though. That's why I ask the best. Thank you all.
