Close
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
  1. #1
    Fresh Catch Magilla's Avatar
    Join Date
    May 2013
    Location
    Monterey, Ca
    Posts
    15
    On Board Air or Co2?
    I am trying to decide between getting on board air or Co2 tanks for our 2013 JK. Many of the forums and discussions that I have found are outdated. I'd like some current product input from people that have used it.
  2. #2
    Nothing but a Thing Jackal01's Avatar
    Join Date
    Jun 2013
    Location
    Houston
    Posts
    2,324
    Here is a thread from last year.
    http://wayalife.com/showthread.php?t=30253
  3. #3
    Fresh Catch
    Join Date
    Aug 2016
    Location
    San Diego, CA
    Posts
    42
    I haven't used CO2 for OBA, but I do have an ARB CKSA12 installed on an EVO-1087 mounting bracket. Its the smallest/cheapest compressor that ARB makes, takes about 40 mins to air up 4 35x12.50x17 from 14psi upto 32psi. It maybe slow but its way better than not having air at all, i used it the other day to air up someone's complete flat. Not sure of the tire size but it went from 0 to 38 psi in about 10 mins or so.
  4. #4
    Hooked Rubicon310's Avatar
    Join Date
    Nov 2016
    Location
    San Pedro, Ca
    Posts
    186
    I have a lot of experience with both. I bought a power tank several years ago and after running several trails and having to air up, I realized that the co2 alone would not cut it. I purchased a via air compressor that works great.
    Here's the advantages of c02:
    Very very fast to air up tires.
    You can run air tools.
    You don't need to hook up to a battery.
    Disadvantages:
    Line freezes if airing up larger tires in cold weather.
    You'll run out.
    Pricey to fill.
    When in a group, everyone asks to use it.
    I've started taking both my via air and co2 tank now.
    I seem to use the via air more although it takes longer to fill tires.
  5. #5
    Fresh Catch Drummergordy's Avatar
    Join Date
    Feb 2016
    Location
    Rancho Cucamonga
    Posts
    20
    Quote Originally Posted by Rubicon310 View Post
    Disadvantages:
    You'll run out.
    Pricey to fill.
    "Say When"
  6. #6
    Join Date
    Feb 2016
    Location
    Rancho Cucamonga
    Posts
    20
    Being a Master SCUBA Diver, I have 9 tanks at home. I used an extra regulator and attached air quick disconnects. I have been using a 63 cfm aluminum tank, mostly due to it's size. It's fills tires up quickly with good filtered air and the refills are only $5. I get about 4 good fill ups on a tank. However, I plan on putting a compressor on the rig too. As in diving, sometimes having a redundant system is good.
    "Say When"
  7. #7
    Knows a Thing or Two cavfighter's Avatar
    Join Date
    May 2016
    Location
    Carson City, NV
    Posts
    753
    For now I use CO2. Its cost effective but one day Id like to have OBA. I wanted to be self sufficent and didnt want to be that guy that begs for air after a run. Rubicon310 has some good points.
  8. #8
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    14,269
    I have the ARB twin. Last time I was out, I did a set of 33s and a set of 37s in 15 minutes. This was airing up both from around 15psi to 29 psi. Bad ass machine.
  9. #9
    Hooked daddyusmaximus's Avatar
    Join Date
    Oct 2016
    Location
    Indiana
    Posts
    186
    I've only had VIAR, but I wouldn't want any tank I couldn't fill myself.
  10. #10
    Been Around the Block Heavyhaul07's Avatar
    Join Date
    Oct 2015
    Location
    Grand junction, co
    Posts
    363
    I've used both both good and bad. If it were me and I had the money I'd get the arb twin compressor it is fast. Or one of the arb compressor as I feel they are faster than the viair. Then down the road a co2 tank for back up
Posting Permissions
  • You may not post replies
  • You may not edit your posts
