Close
Results 1 to 5 of 5
  1. #1
    Fresh Catch Cpeters's Avatar
    Sep 2016
    Surrey, BC
    1
    Headlight DRL help
    Hey jeepers,
    Need help with a situation. I replaced my stock headlights with LED's and they require the DRL to be wiring into the fuse box in an ACC port? I've looked online and thought I had it in the right slot, but my dash flashed warnings saying the left and right overcharging ? Checked this by plugging in my super chips flash cal.
    Any ideas? I appreciate any direction.
    2015 jku
    Thanks
  2. #2
    Knows a Thing or Two Goldeneagle1LC's Avatar
    Oct 2015
    Plant City, Fl
    539
    Test the wiring harness for the lights and find a wire that is hot when the Key is on. Tap into that wire. thats how I have mine set up
  3. #3
    Been Around the Block
    Jul 2016
    Vancouver Canada
    257
    Quote Originally Posted by Cpeters View Post
    Hey jeepers,
    2015 jku
    Thanks
    Could you elaborate on which headlights you are installing? Different models will have their own harness.
    Welcome btw, good to see another local.
  4. #4
    Fresh Catch
    Aug 2016
    pei,canada
    12
    m8 or m9 on the fuse box
  5. #5
    Old Timer jeeeep's Avatar
    Oct 2011
    Tx
    4,001
    Quote Originally Posted by Goldeneagle1LC View Post
    this is how i did it as well
