Hub assembly
Dopey84
So my driver side hub assembly has a bit of play in it and needs replaced... I'm looking for suggestions on what to use as a replacement my wheel speed sensor is still good so I'm looking to use it with the new hub assembly ready and let's hear what you got
Dopey
jeeeep
Dopey
fronts? they all come as a single assembly with new abs lines, sometimes you can reuse the same line depending on which is longer but it's not that big a deal to swap them out if needed - or keep them as a spare
i like O'Reilly brand Precision Hubs, 3 yrs replacement warranty no questions
Dopey84
Sorry yes front driver side
Dopey
cozdude
Guy with a Red 2-Door
Actually it's not what I seek... although it makes it easier than searching for the write up again.. I'm looking for specific hub assembly's people have swapped out to aside from the timkin Eddie uses.. just looking at options
Dopey
You can just google JK unit bearings and it should pull up many options.
I personally use Timkin like eddie does cause they make some of the best bearings on the market. They are also some of the cheapest assembly's I have found on my searches thru rockauto and other parts suppliers.
aermotor
Dopey
In your original post you didn't say you were looking for alternatives to Timken, so that's why I linked it figuring you hadn't seen them. Good times.
I used the Timkens with good results.
jeeeep
I have timkins on now, ordered them on the road since that's what I could get on Amazon at the time and would ship to my hotel next day.
when I got home I took the O'Reilly Precision hubs back to O'Reilly and they were ready to refund my full purchase price (they were almost at the 3 year warranty expiration) I opted to get new hubs.
Timkin kept giving ABS errors off and on. I did not use the Timkin ABS cables since they were shorter than the extended cables I have installed and the cables work fine with the Precision Hubs.
Timkin have a 1yr warranty - Precision 3yr
I'll eventually have enough spare parts to build another Jeep :doh:
Dopey84
Well thank you I'll look into the timkens as it was probably what I was gonna use.. was just trying to get other suggestions/options... wasn't meaning to be rude by my comment as I just re read it and realized I sounded like an ass my apologies
Dopey
cozdude
Yes the timkin speed sensor wires are shorter but they are plenty long. They don't get in the way of my coilovers fully drooping
aermotor
Dopey
No worries
JRUnlimited
I replaced mine with Moog brand hubs and they have worked well for the last 2 years. I can't say they're any better than the Timken hubs and there is no particular reason why I chose those over other brands other than the price was right.
