Air Pressure Nitto ridge grapplers?
LAJK
I recently purchased a set of 37x12.50R17 ridge grapplers and want to find the perfect air pressure so you wear evenly. I'm currently running 35psi and was curious what others had them at??? IMG_0202.jpg
jeffj
I ran 26 psi in my 37 trail grapplers. I think you'll get a lot smoother ride at 26 or 28. The key to getting good wear is rotating them every 3000 miles. In my opinion
mo0s3
That's what I did with my Toyo MT and I have about 35k on them with a little under 50% tire wear . I going to go with the bottom next and will for sure do the same advice as the above has said !
madstiles
It varies depending on weight and outdoor temperature. Do a chalk test there's videos and write ups to show you how it's quick easy and takes the guessing out of it.
