It's Time to SUPERSIZE Moby - MoTech 6.2L LS Jeep Motor Swap
jeeeep
this is great!!! my 2010 gets paid off soon and then LS here I come!! can't wait to hear it fire up! :beer:
bluewave
Thst is where my jeep is at right now. Ive told everyone if you are questioning 5.3 vs 6.2 go with the 6.2. I know the hemi felt like it could use a few more horses on a few occasions
Sent from my SAMSUNG-SGH-I747 using WAYALIFE mobile app
CarsonCindy
Curious to find out what you think of your gearing!!
Having just got my Jeep finished up and out on the road, I am finding that the gearing might be a touch too much (5.38) here as well. In 4lo mine feels really over geared, almost like I am using an atlas in super low. I need to put more miles on it, and get some off road time in as well before I make up my mind for sure if I like the 5.38's on my setup. Maybe your 6 spd tranny will make it nicer for you than my 5 spd does for me!!!
I'm curious to find out too! :D Hopefully soon! As far as 4lo goes, we specifically went 3:1 instead of 4:1 like the rubicon transfer case has so maybe it won't feel as low as your setup. We'll see.
CarsonCindy
Your build looks awesome! Welcome to WAYALIFE!
CarsonCindy
DAY 6 - BODY TOUCHDOWN
Here is a brief summary of what we accomplished on day 6...
-Changed the oil
-Installed sensors
-Installed new dipstick
-Installed trans cooler lines
-Installed new wires
-Installed new PSC pump
-Installed MoTech Emissions Kit
-Assembled new radiator
-Installed new radiator
-Re-attached body to frame
Time for our first oil change
One of several new sensors installed
Installing new transmission cooler lines
Installing new wires
New PSC pump installed
Installing MoTech Emissions Kit and fuel lines
Assembling new radiator
Lowering the body to install new radiator
Installing new radiator
Repositioning the frame to get it lined up for the body
Almost ready to lower the body back onto the frame
Checking clearance as the body is lowered
Touchdown!
Sudz
i would have replaced the a/c condenser - or at least power washed it..
they're not that much $$$ and now is the time to do it
CarsonCindy
Yeah, we probably should have at least given it a good cleaning, but we thought about it a little too late. :doh:
Sharkey
Word Ninja
Cindy- I keep forgetting to ask if you will be able to keep the dual batteries with your new setup. Hard to tell for sure from the pics, but it kinda looked like you might have the room.
CarsonCindy
It was close, but the dual battery tray just didn't quite fit. We ended up installing a factory tray for now.
ttfhell
We aren't. Currently, we just have our bypass shocks setup so that the 3rd and final one acts like an air bump.
Eddie, if the third isn't set up as a bump stop what would it be used for?
Thanks
Russ
CarsonCindy
DAY 7 - WIRING AND INITIAL FIRE-UP
Here is a brief summary of what we accomplished on day 7...
-Installed PCM and ECM
-Wiring, wiring and more wiring
-Installed radiator overflow bottle
-Installed radiator hoses
-Installed new gas pedal
-Removed old transfer case shifter
-Tapped into the TIPM
-Installed our instrument cluster
-Installed a factory battery tray (our dual tray would not fit)
-Installed battery
-Test fired the engine
The PCM and ECM installed
Wiring, wiring, wiring
Installed radiator overflow bottle and hoses
Out with the old transfer case shifter
Tapping into the TIPM
Installing our instrument cluster
Installing the battery
Yay! :wings: Got Moby's new LS fired-up for the first time!! (Video coming soon)
