GraniteCrystal
This is a condensed view of all the trails on traildamage.com.  In no way is this meant to be a replacement for the invaluable knowledge available on traildamage.com.  Those folks have spent hundreds of hours creating that knowledge based and my heartfelt thanks goes out to them for doing so.
This was created simply because I lacked a good way to filter trails. For example, I may want to know all trails that are in the 4-7 difficulty range with some great scenery in certain counties. That feature isn't available to me on traildamage.com but is easily done using this spreadsheet. Use the dropdowns at the top of each column to filter based on what you want.
If you work for traildamage.com and find this to be a violation of any of your legal rights, please get in touch and I'll be happy to take it down.
If you like this and want to filter by more stuff, shoot me a pm.
The data on the TrailList sheet has to be editable for you to be able to filter/sort it. Please, do not change any of the values and use Ctrl+Z if you accidentally do change something. I'll do periodic refreshes of the data in case people try to screw with it.
Disclaimer: google docs allows multiple editors, so things might get a little wonky when multiple people are filtering/sorting. In general, there will probably only be 1 person at a time on here so it shouldn't be a problem.
https://docs.google.com/spreadsheets/d/1AhDyXf91m0VhUveQLHTdv42KBqC6AAq1RyHEqMIkCgc/edit?usp=sharing
