Hack12
For starters, I have a 2008 JKU Sahara with 61,000 miles and an automatic transmission.
While changing my transfer case and differential fluids today, the technician at Valvoline noticed transmission fluid leaking out of a line under the engine.
I have an appointment with my dealership tomorrow morning to fix my gas regurgitation issue and change my transmission fluid. I chose not to have my transmission fluid changed at Valvoline because they only offer a flush and I wasn't sure whether I should do that or drop the pan and change the filter.
My questions are:
1- Does this look like a leak and, if so, will it be expensive to have it fixed while my Jeep is at the dealership tomorrow?
2- Should I have the dealership flush my transmission fluid or drop the pan and change the filter?
3- Though Valvoline had the ATF+4 properly recommended for transfer case fluid, they recommended 75w140 for the differentials. Following the Project JK write-up, I told them to use 75w90 synthetic in both the front and rear differentials. Did I do the right thing by choosing to use the 7w90 synthetic gear oil?
My questions are:
