Evo Spec 14" Col Over Kit Spring Rates
FastEddie760
I'm curious to see what coil spring rates anyone else with this kit ended up with.
Im a lightweight build on 39s with no rear tire, aluminum skids, stubby bumbers and Teraflex IR long arm kit.
Lift: Right arouind 5"
Front springs: 200/300. About 5.25" of shock shaft showing at ride height.
Rear springs: 150/200. About 4.5" of shock shaft showing at ride height.
This setup would be great for rock crawling, but not enough shaft showing for desert running. I will be welding in coilover brackets to raise the mounting locations a couple inches.
I have 250/400 up front and 200/350 in the rear.
392 that I wound consider to heavy with extra stuff, since a spare 38. I ultimately went with 350 in the rear because I do have a rack and tent on from time to time and it’s perfect when I’m loaded up, but maybe a bit stiff when unloaded.
