Jimmypaget
P0198 code decided to pop today. Anyone know where this sensor is and how to swap it out for a new one?
			Damn that doesn’t sound very easy to get to. Probably take an afternoon to tear into it. So where do I find a new sensor?It’s on the side of the block. Driver side behind the cat between that and the tub.
Actually that’s easy to get to. Unfortunately I read your post wrong. That one is the coolant temp sensor. The one you need is under the intake manifold. Need to remove the intake and possible the oil filter housing. Can’t remember for sure. It’s a half day worth or work. Maybe look at replacing the whole filter housing while you have it in there.Damn that doesn’t sound very easy to get to. Probably take an afternoon to tear into it. So where do I find a new sensor?
Well damn. I’ve got no way of pulling the motor out. Guess I’ll search the YouTube mechanics videos to find out what I’ve gotta do.That’s with the motor removed. Not easy with the motor in.
if you have the 3.8 it's easier to get to than the 3.6P0198 code decided to pop today. Anyone know where this sensor is and how to swap it out for a new one?
