Two words in favor of OBA - Air Horn.
Hell yeah! It's so satisfying blasting that asshole who just tried to run you off the road with 130db.
CO2 Pros
-You can build a system for cheap
-Very Fast
-can run air tools
CO2 Cons
-$$$ to refill
-will eventually run out
-big in size
OBA Pros
-Unlimited air
-Small
-lockers
OBA Cons
-Slower than CO2
-a good system isn't cheap
-can't run tools without a storage tank
I'd like to have both. A twin arb set up, and one of those big bottles on the back of the roll bar. What's a good brand for the CO2?
I weighed both systems a while ago & ended up going with the OBA. I mounted an ARB twin under the passenger seat. It's out of the way and out of the elements so it should last as long as the vehicle. Finding a place for the CO2 tank that's out of the way means you probably will end up mounting on a roll bar, which is ok, but I didn't want to run exposed air hoses that could get snagged inadvertently. The compressor's just too convenient & I didn't want to chance running out of air either - more than likely because I forgot to fill the damn tank.
So everyone is saying ARB, does no one like Viair?
