Picked up some coolant and filled reservoir .. was a tad low . Also went under and did an inspection and found rear sway bar link nut missing .. bolt was just hanging in there .
So last Xmas I built a set of rock rails for the New Years Run, but didn’t have time to finish fabbing or installing additional bracing. So before I head to the Rubicon on 8/5, figured I’d better pull them off and finish the job before the Rubicon or Fordyce wipes them out. So last weekend I made all the braces.
Nice workmanship. Looks great!
I know. I’m gonna take it to the dealer in a couple weeks and have them fix it. I can’t get this evap leak figured out so I haven’t been able to register it in two years. Then I think I’m gonna lower it an inch and fix some stuff with it so I can at least drive it. It’s either stretch that or LS the four door. Thinking probably more the latter.
Stretch the 2 door. I need inspiration. [emoji23]
Sucks I just started an evap code. Hoping doesn’t come to this.
But can you build a solid argument I can sell on buying a built Unlimited?
