Foofighter3
Hi all,
My 08 Wrangler X 2 door started making a sort of jolting motion that you can feel in the cab whenever I accelerate from a stop, accelerate from a slow 1-3 mph speed, or shift into reverse or drive. This happens most of the time but not 100% of the time. It usually does not happen if I very slowly apply the gas.
I had a lower control arm/track bar bolt replacement kit lying around so i went ahead and installed those, torqued to spec, and torqued all the upper control arms to spec as well, that did not fix the jolting.
What do you think? Transmission mount or engine mount or?
Thanks all!
UPDATE: Problem was due to excessive play in the drive shaft caused by bad auto locker install.
Thanks all!
