Holeshot
Banned
Ordered my truck-lite's / dually's combo on dec. 10, received my duallys today, but still out of order in TL at northridge so I'm patiently waiting.
Will install them tonigh after work, I'll post pics later.
JKAnimal
Is that the kit (in the smaller box) so you can mount them in the front or rear bumper?
Your going to love those Rigids!
jeffj
Nothing exciting but took the day off work today pulled and greased both drive shaft, changed diff fluid, rotated tires and changed oil. Nice little Monday.
darkscion0
Installed RC 2.5" spacer lift + trackbar bracket in anticipation of 35" tires. Looks great even with stock tires and didn't change the driving characteristics.
jkrossi
2.5" spacer lift completed finally with 35" tires and no rubbing.
Sent from my DROID X2 using WAYALIFE mobile app
Holeshot
Banned
Yes it's the kit from rigid for fog flush mount.
I had a hard time aiming them properly. probably because of my custom bumper fog chanels. I Decided to go with spot pattern instead of flood so I can keep them on while on the street. The pattern is much concentrated. But afterward, spots are doing a very narrow beam in front of the jeep.. Maybe because I installed them too deep in the channels or because they're spots. So I wonder if I should have chosen floods instead. :thinking:
Rebel has them for $10 cheaper.
For the pair or for the combo of TL's and duallys?
jkrossi
What 2.5 kit did you use? I have the TF and still had rubbing before wheel spacers.
Sorry, i forgot to mention it is the TF kit an i did use spacers 1.25'' in back and 1.75'' in front. one thing i dont know why the said to put the sway bar links in the inside of the brackets. I did that and they rubbed on the track bar bracket and rubbed on the drivers side as well. so i put them in the stock positions.
