cocokrispes
Great stuff!! I look forward to implementing this the future.
Sent from my SM-G930V using WAYALIFE mobile app
I cut the same amount off for my 40's but then I took the piece I cut out and used it to trace a flat steel sheet and welded it over the opening so the foam isn't exposed. Now it looks factory![]()
Welcome to Wayalife. I'm sure it looks clean, but I've had a hell of a time welding that area even with low heat. It just blows holes through the metal and that foam inside caught on fire on one side on me so I gave up.
Here is the metal plate tacked into place before I started filling the edges and smoothing it out
Any fears welding with that filler foam back there? I thought about that option, but steered clear due to worrying about that foam catching fire. It does look good that way.Here is the metal plate tacked into place before I started filling the edges and smoothing it out
Eddie, did you need to do any clearance work on the front wheel wells?
Sent from my LG-H918 using Tapatalk
I'd appreciate that. I'm likely going to make the jump from 37s to 40s on my next set of tires, and my 37s are getting into the rear of the well already. I think you're running the same amount of lift as I am, so I was curious how you got 40s to stuff properly up front.Yes, I had done quite a bit of trimming up front in the past, back when I was running 40" Mud Grapplers. I'll try to take a post up some pics of it today.
And you have the DTD as well correct? Are you running 12" coilover's and if so how much up travel do you have? I'm trying to understand how LCG you are on 40's compared to mine on 37's.
Perfect! Thanks for taking the time to help me out!Compare the pic I posted up with what's on your Jeep for a more accurate comparison but this is about what was removed.
Yes, they clear 100% now.
