LOL!! I love all the variety of info here! I was in your exact same situation when I installed my Adams front 1350 drive line. It requires you take the factory pinion flange off the front axle and install a different one on. So, after sifting through all the different opinions, I called Adams and spoke to one of their techs. He told me yes, there IS a crush-sleeve and NO, there isn't a set torque number you can dial up and hit with your torque wrench. This is the "go-on-your-own" part. Since I wasn't using an impact wrench he told me to use my breaker bar and tighten the nut down "tight". WTF right? Well that's what I did and I did feel the nut tighten down and kind of stop. I applied a bit more pressure and then I felt the nut kind of "give" a little bit. That's right where I stopped. No problems since then and 15k miles later still no issues. There isn't a definitive answer on this. You can take all the readings you want, but short of completely stripping and replacing every part in the front end, this is another method. Good luck James![emoji106]
Sent from my iPhone using
WAYALIFE mobile app
