Reid knuckles, painted my tie rod and drag link, replaced a few grease boots and test fit the new tires
Looks great!
Found a local shop and dropped the JLU off for the cylinder 3 misfire, they called and told me they swapped the plug, coil, fuel injector to different cylinders, still getting misfire on 3 at higher rpms.
Time for further investigation, they will remove the valve covers and take a look, also told me the noise I thought was coming from the driver side is actually on the passenger side - cylinder 3 side.
They'll get back to me on Monday to let me know what they've found.
Ugh, hope it’s a simple fix.
Time for a leak down check
Got the Jeep back, so quiet and full rpm range ready
Cylinder 5 lobe was also worn and ready to make its debut of a misfire.
Some of these lobes are not like the others:
It's nuts. I've worked in the auto industry a long time and I've never seen cam lobes wear down so deep like these 3.6s. Nearly all of them do it. I really wish they built shit like they used to.
