Starting and stopping problems
MitchandJenny
Again.
What WERE the codes.
Just because you replaced a sensor doesn’t make it “good” it doesn’t make the wiring “good”
When it shuts down:
DOES IT HAVE SPARK
DOES IT HAVE FUEL PRESSURE
Do you lose power completely or does it just turn off like you turned the key
Will the starter turn over the engine after this happens
Does it make any sputtering or backfiring sounds when turning over
I have no spark and the computer was replaced and it did the same thing. It ran for like 30 minutes and shuts off. Could it be the ignition switch. Haven’t checked that yet. It had fuel pressure
