MAINTENANCE : Bleeding the Brakes on a Jeep JK Wrangler
ABS BLEED .
Does anyone know if the Jscan app can activate/cylce the abs in order to get air out of the abs side ?
Have recently bled the system still feel the pedal is soft after a flush of the main sytem.
Sent from my SM-T810 using WAYALIFE mobile app
cozdude
Guy with a Red 2-Door
ABS BLEED .
Not sure but you can do an abs bleed without a scan tool. If you create and “ABS event” you will force the unit to force the air out. Do this about 3 times then go rebleed your brakes.
