NEW WAYALIFE Cowl Decal NOW AVAILABLE
JAGS
Did anyone else have troubles with the little letters? Those little fers wouldn’t come loose from the paper so I ended up with the word Wayalife on both sides but not the whole sticker. Apparently I’m challenged in the sticker application department [emoji851]
Be sure to clean the area with a mild degreaser first, especially for smaller pieces to hold to the surface. Diluted rubbing alcohol and a cotton ball work for small areas. I've also used simple green followed by windex. Then just take your time with the backing and an old gift card works great to get the vinyl to stick.
What JAGS said is very helpful especially with the rubbing alcohol. However, if you're saying that you got decals where the paper backing stuck to the letters, send me a PM with your full name and shipping information. The black vinyl is pretty thin and a handful of decals cut a bit deep in those areas. I'll send out a new set.
JKbrick
I used a little square alcohol pad like the kind when you get a shot, then I got the sticker off the backer ok but just a couple of the small letters didn’t stick to the jeep when I tried to pull of the transfer paper or whatever it is called. Either way it’s not your fault and you don’t owe me new stickers. I’ll order some new ones when I get shirts next time
RMC2
I like these. Except I saw say he is SALUTING, not shielding his eyes.
I may be biased though.
jdofmemi
I ordered these and put them on a while ago, but completely missed this thread.
Did my JK in gold to go with the other parts like the cage, beadlock rings, and tire carrier.
The new Wayalife had to be black though.
