Suspension help please. Axle off center w/ sway bar links being flexed out.
JudeinPa
You need to shorten up that trackbar homeslice. Measure the difference between the two sides than divide by two. Shorten it that much and that will center your axle. For example if your passenger side tire sticks out two inches more than the drivers side shorten the trackbar by one inch
I am no expert by far but I think CrazyLarry's response will correct your problem. Your track bar looks like it is adjusted out too far and if you follow his directions it will move your passenger side towards the driver side.
