What Grease Should I Use?
zeddjb
Sorry if this has been asked/answered/discussed somewhere before. I just recently replaced the rear upper and lower control arms (Currie) on my 2012 JK. They come pre-greased but I figured I should hit them with some grease anyways.
2013-09-11 12.08.50.jpg 2013-09-11 12.10.27.jpg 2013-09-11 12.13.29.jpg 2013-09-11 12.13.37.jpg 2013-09-11 12.13.43.jpg 2013-09-11 12.16.22.jpg 2013-09-11 12.16.32.jpg 2013-09-11 12.16.36.jpg 2013-09-11 15.59.41.jpg 2013-09-11 15.59.53.jpg 2013-09-11 16.00.01.jpg 2013-09-11 16.00.11.jpg
I was curious, since there were no spec sheets that came with the CAs, what type of grease should be used? I probably should have asked this before I used what I did, but it didn't occur to me at the time.
This is the type of grease that I have been using for the last 5 years on the Rough Country CAs. It is a red - hi temp type:
JT2012Jk
Noob question but why did you switch out the control arms. Is it affiliated with getting a lift.
JT
Don't Tread On Me!!!
zeddjb
JT
I replaced the Rough Country CAs I had because they were getting old and one of the seals was blown out and I could no longer get grease to stay in. Because of this, there was a very loud squeaking coming from the old CA and unfortunately they were not rebuildable.
I figured I may as well upgrade to a better product and a few people suggested Currie. I really like these CAs because they are rebuildable and the heads on them are pretty beefy in comparison to the Rough Country ones I had on there. I don't suspect I'll have to replace these for at least 5 years or longer. Probably just have to buy a couple rebuild kits.
