Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 96
Thread: Short arm vs long arm lift question
  1. #81
    Old Timer DWiggles's Avatar
    Jul 2014
    Texas
    3,714
    Quote Originally Posted by Dirtrider.... View Post
    Have any of you been disappointed and regretted installing a long arm kit? What are the biggest drawbacks to the long arm vs standard short arm kits in your real world experience?
    I have a 2012 JKU with a 3inch lift on 37s... lift was on the jeep since 2014 when we bought the jeep.
    My main off-roading adventures are rock crawling and exploring. I run out of up travel quickly on dirt roads so I keep speed down especially when loaded up with camping gear. Would be nice to drive down a dirt road at 45mph and hit a dip without bottoming out the rear.
    Been thinking about refreshing the main suspension items... we've put over 100k miles on her since we've owned her and she's my daily driver.
    You would need to either lift the jeep, or run smaller rear bumps (I assume trim the rear pinch seams) in order to get more up travel... which is what you will need to go "down a dirt road at 45mph and hit a dip without bottoming out the rear"
    not really understanding what any of this has to do with installing long arms or not but get 4" springs and some decent shocks, keep the 3" bumps in the rear and be two tits to the wind.
    ...Or...
    Make the jump to coilovers...
  2. #82
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,825
    Merged here.
  3. #83
    Old Timer TrainWreck618's Avatar
    Oct 2015
    East of St. Louis
    2,927
    I have never regretted my long arm decision, that being said it’s not going to change your travel.
  4. #84
    Addict Ddays's Avatar
    Aug 2015
    Darlington, Pa
    9,623
    Don't regret for a second moving up to long arms. The only issue I have is with that the high clearance mounts weren't available in the kit I bought when I did this a couple years ago. The frame mounts for the rear control arms constantly catches and drags on shit exactly when you don't want it to. Now that the high clearance mounts are available separately I'm getting those installed.
    If you're even thinking about it you should just do it now and not regret it later on.
  5. #85
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,283
    ^^This^^. What Ddays said. I’m in exactly the same position and will be upgrading the mounts. Don’t regret it one bit
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  6. #86
    Hooked KevinG's Avatar
    Jan 2019
    Sudden Valley Washington
    125
    I am in the same camp as these other guys. Had a short arm/ geo bracket life and went to long arm. As far as loads, we pull a 3000# pop up over the North Cascades every few weeks in the summer and it's performed flawlessly on and off road... other than what Ddays mentions below. Yes, it was a lot of work, but I would have put in twice as much effort to get it to ride like this. If you search my posts, I put a lot of pics up of the install.
    Quote Originally Posted by Ddays View Post
    I need those high clearance mounts.
  7. #87
    Nov 2016
    Rochester, MI.
    6,283
    Quote Originally Posted by KevinG View Post
    You and me both
    2015 JKUR AEV JK350
    1985 CJ8 Scrambler
  8. #88
    Aug 2015
    Darlington, Pa
    9,623
    They're beauties! Can't wait to get rid of the damn shovels on my frame I have on now...
  9. #89
    Fresh Catch
    Jun 2016
    Southern California
    42
    Thanks for the feedback... my long-term goal is to install an evo long-arm high clearance kit and bolt-on coilovers ... my pocketbook doesn't seem to agree at the moment...
    one local shop quoted me 30 hours of install time to install both the long-arm kit and bolt on coilovers. Does that amount of time seem correct in your experience with the install? the install is way above my youtube watching mechanical skills... lol so its definitely not a project i will attempt to tackle.
    ohh an I did install a stock front sway bar to replace the currie anti-rock... WOW what a difference. very happy with the highway driving again. who knew. now on to search for a good set of quick disconnects for the front sway bar.
  10. #90
    Aug 2015
    Darlington, Pa
    9,623
    30 hours is probably a good estimate. Theres a shitload of cutting, grinding and welding to be done on those mounts.
Tags for this Thread
