Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: JEEP TECH : How to Install ATX Slab Bead Lock Wheels Video w/ Off Road Evolution
  1. #61
    Nothing but a Thing ERAUGrad04's Avatar
    Join Date
    May 2014
    Location
    SF Bay Area
    Posts
    1,486
    Hmm, maybe some folks with more experience, however, I was pretty certain you want that ring making contact with the wheel. My 37" Nitto Trail Grapplers mounted up to Slabs with no gap and the ring is solidly against the wheel.
    If you have a gap, the bolts are providing all of the holding power. Also, the bolts could "bend" slightly since the ring is not flush. However, if the ring is flush to the wheel, the surface friction between the ring and wheel provides additional holding power (similar to the way lugs hold a wheel to the axle).
    2014 Unlimited Rubicon
    Mauser's Build Thread
  2. #62
    Hooked Big b's Avatar
    Join Date
    Feb 2012
    Location
    Social Circle, Georgia
    Posts
    108
    I talked to a representative at Spyderlock wheels (same wheels as ATX slabs) a couple of years ago about this same issue. His reply was that not all tires are created equal and some have thick beads. The ring should be torqued down evenly and you should get metal to metal contact. 25 ft/lbs is recommended torque setting, but if you have a tire with thicker beads you should not exceed 35ft/lbs to get even seating of the ring to wheel. I'm not sure if ATX or Spyderlock offer shims, but know that other bead lock manufactures do for this same issue.
    But please don't take my word on this and call the manufacture.
  3. #63
    Old Timer Moochie's Avatar
    Join Date
    Nov 2011
    Location
    San Diego County
    Posts
    3,499
    No more than 22 - 24 ft/lbs per ATX instructions.
  4. #64
    Join Date
    Feb 2012
    Location
    Posts
    108
    Quote Originally Posted by Moochie View Post
    This is why I called Spyderlock (original manufacture of these wheels) when we had tires that wouldn't allow the ring to seat. Their instructions also stated to not exceed 25 ft/lbs. that's when I was given the max torque of 35 ft/lbs. This situation took 32 ft/lbs to have ring to wheel contact. I'm in no way saying that you should torque the bolts over ATX's recommend 24, but I would contact them before running the ring not completely seated.
  5. #65
    Join Date
    Feb 2012
    Location
    Posts
    108
    Sorry for multiple post just found this in the FAQ section.
  6. #66
    Fresh Catch sweno's Avatar
    Join Date
    Feb 2015
    Location
    Australia
    Posts
    24
    Hey guys. Just for my Atx slabs. Was told that I can't run more than 18psi in them on the road. Is that true. What is the max I can put in them?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
