I've found that airing down to 20psi works great in most situations be it sand, rock or mud plus then it leaves you the back up of being able to let a little bit more out if needed.
Dropping to 12 straight away seems a bit extreme and until you know your rig and can read the trails you'll run a higher risk of rolling a tyre off the rim.
