Results 1 to 8 of 8
Thread: 1350 or 1310??
  1. #1
    LOSER
    Join Date
    Aug 2013
    Location
    Loserville
    Posts
    172
    1350 or 1310??
    Going to buy a new rear DS. I run 37s, 5.13 gears, ARBs, and about 4.5" lift. Should I do a 1310 or 1350 DS? Also, I've been told that stock length is ok, no need to get a longer one. Thoughts, input, any help appreciated. Thanks
  2. #2
    Fresh Catch
    Join Date
    Jan 2014
    Location
    MN
    Posts
    16
    Quote Originally Posted by T&ERun View Post
    07-11 or 12-14? 2 door or unlimited?
  3. #3
    Nothing but a Thing
    Join Date
    Nov 2012
    Location
    us
    Posts
    1,343
    4.5" , that's way too much for a 2DR and the majority of the 4DR run 3.5" to 4"
  4. #4
    Fresh Catch
    Join Date
    Jan 2014
    Location
    MN
    Posts
    16
    In the Sitcky JK FAQ it says
    Q: What are all the components that I will need with a 4" lift?
    A: For a 4" lift, you should have a set of 4" coils, bump stop extensions, longer shocks, extended brake lines, longer sway bar links, adjustable front track bar, adjustable rear track bar, front and rear track bar relocation brackets, dropped pitman arm, adjustable upper and lower control arms front and rear and new double cardin u-joint style drive shafts.
    On a 2012-Up, you will want to install a new front drive shaft regardless if you have an automatic or manual transmission. Assuming you install new, longer shocks with your lift, the extra droop you will see at a flex will cause the slip shaft boot on the drive shaft to tear. However, that is just one problem you will encounter. Even if you install exhaust spacers or relocate the cross over, the CV boot at the output shaft will be sitting at a significant state of pinch and this will cause it to fail prematurely.
    as far as 1310 or 1350. i have a stock motor and run 35's. my coast 1310 has given me no problems. if you have swapped in a v8 you should start looking at the 1350's because of the increase in torque and horsepower.
  5. #5
    Hooked quit staring's Avatar
    Join Date
    Nov 2013
    Location
    Hyde Park,NY
    Posts
    202
    I am running a 2014 rubicon with 37's 5.13 auto 2 door with about the same amount of lift. I opted for 1350's front and rear In case I ever go 40's. I had 1310's on my old 2010 with the same setup just a sport and never had any problems
  6. #6
    Old Timer RockyJk's Avatar
    Join Date
    Jul 2012
    Location
    SoCal
    Posts
    3,691
    I asked JE Reel about this at the expo last year and they told me for 35's 1310 works and if your going bigger than 35's to run 1350's....
  7. #7
    Fresh Catch
    Join Date
    Jan 2014
    Location
    MN
    Posts
    16
    Quote Originally Posted by RockyJk View Post
    Good info! if anyone should know it should be the guys who make them.
  8. #8
    LOSER
    Join Date
    Aug 2013
    Location
    Loserville
    Posts
    172
    Sorry. 2007 Unlimited (4Dr).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
