Page 1918 of 2019 FirstFirst ... 918141818181868190819161917191819191920192819682018 ... LastLast
Results 19,171 to 19,180 of 20189
Thread: What was done to your rig this week?
  1. #19171
    Been Around the Block PokerStogey's Avatar
    Join Date
    Apr 2016
    Location
    Bakersfield
    Posts
    422
    Quote Originally Posted by danford.lau View Post
    Attachment 322574
    Attachment 322575
    Attachment 322576
    Attachment 322577
    My 37” Cooper stts on machetes at cougar buttes
    Looks good man!
  2. #19172
    Fresh Catch Boudica's Avatar
    Join Date
    Feb 2019
    Location
    Louisiana
    Posts
    17
    So I went to change out the stock differential covers this afternoon. It was the first nice day we've had in a while (which is necessary as my Jeep doesn't fit in the garage and the carport is uncovered). Everything was going great- all the tools were lined up, brand-new bottle of Permatex Right stuff, step-by-step instructions written out and in view (it was my first time doing this, I didn't want to forget anything).
    Fill bolt removed, drain bolt removed, fluid is flowing out. Let that go for a bit, move on to removing the cover bolts with the hand ratchet...not budging. Tap the ratchet with a rubber mallet...not budging. Cheater bar...not budging. Crap.
    I live out in the boonies. It's an hour round trip to Home Depot. Now I'm the proud owner of a Milwaukee impact wrench (well, and a new cordless drill, too, but that has no bearing on this story). Try the wrench with the charge it's got straight out of the box...not budging. Colorful metaphors are now flowing.
    An hour later, with a fully charged battery, not a single bolt is budging. Evidently, whoever put on the covers at the factory owns stock in their gasket-making stuff. Looking at the bolts, the RTV has oozed up out of the bolt holes and around the edges of the bolts. It's squeezed out around the perimeter and I can peel dried lengths of it off.
    So, since this is my DD and I have to go into work tomorrow, I had to refill the still-stock front differential after about forty-five minutes of trying to loosen the bolts with absolutely no success.
    I'm headed to the dealership within the next two weeks for new tires. Hopefully they'll be friendly and use their air-impact wrench to loosen these bolts and then tighten to torque so I can get this done at home.
    Sorry for the long-winded explanation. I don't have any beer in the house, so I came here to vent.
  3. #19173
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    31,612
    Quote Originally Posted by Boudica View Post
    They shouldn’t be that tight. Try a little heat.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  4. #19174
    Nothing but a Thing nbunga's Avatar
    Join Date
    May 2017
    Location
    Northeast Indiana
    Posts
    1,258
    Lefty loosey?
  5. #19175
    Knows a Thing or Two danford.lau's Avatar
    Join Date
    Jan 2018
    Location
    West Los Angeles
    Posts
    834
    Quote Originally Posted by rubiDave View Post
    Yeah, I figured.
    How's your brakes & steering?
    Brakes are actually okay . Still going to get the pro grips eventually but they are now 2nd priority after a tie rod .
    Steering seems fine for now too . Tie rod still straight . Steering wheel has to be recentered after every wheeling trip ... threw some blue loctite on last time and it still came loose again . 2 bolts don’t seem to do a good job holding it in place
  6. #19176
    Join Date
    Feb 2019
    Location
    Louisiana
    Posts
    17
    Quote Originally Posted by OverlanderJK View Post
    No torch of any kind, unfortunately.
    Quote Originally Posted by nbunga View Post
    Lefty loosey?
    Lol, a valid question, but I did triple-check that. I even tried tightening a little and then switching back to loosening to try to crack whatever seal is in there, and also to check my direction.
  7. #19177
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,640
    Are the clamps lined up with the split in the adjuster properly? If the bolts aren't perpendicular to the split, it doesn't tighten it down enough to hold it in place.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  8. #19178
    Knows a Thing or Two A.J.'s Avatar
    Join Date
    Jun 2015
    Location
    Grants Pass Or.
    Posts
    935
    I’ve had pretty good luck with over tight bolts hitting them with a big blunt end brass drift punch or an old diff pin made into one. Good sized ball peen hammer and just hit the top of the bolt like your trying to drive it in to the case. Then try your impact again. Worth a try.
  9. #19179
    Been Around the Block jjlong's Avatar
    Join Date
    Apr 2015
    Location
    SoCal
    Posts
    441
    Installed a Adams Driveshaft.
    Attached Images Attached Images
  10. #19180
    Fresh Catch Avis's Avatar
    Join Date
    Jul 2017
    Location
    Chandler AZ
    Posts
    43
    Got a PSC Big Bore Steering box installed, and front / rear Adams driveshafts installed.. don't have a pic of the shafts :/
    Untitled by Daniel Avis, on Flickr
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
