Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Trouble mounting slab beadlocks
  1. #1
    Fresh Catch Tmac's Avatar
    Join Date
    Feb 2014
    Location
    SW Missouri
    Posts
    3
    I've never had beadlocks so bare with me, I can't get the ring to sit flush on the wheel. It's almost like the bead on the super swampers I'm trying to mount is too thick? Don't know if a gap is ok between the wheel and ring or not? Just don't want to over torque the bolts. Any help or info would be great! Thank you in advance.
  2. #2
    Addict StrizzyChris's Avatar
    Join Date
    Apr 2012
    Location
    SouthWest OH
    Posts
    5,164
    When you say flush, do you mean that the ring is level all the way around the tire or that the ring metal is directly on rim metal flush? If the latter, then no it wouldn't be flush and you can expect to have an internal gap. Fallow the torque specs for the bolts and keep working in a circle. Over torque them and risk stripping the rim threads or snapping a bolt. You just want to make sure the tire is completely around the wheel's mounting lip uniformly, and not caught up on it at all.
    2013 Dune JKU Rubicon <-- Build Thread
    37" Nitto Trail Grapplers on 17" ATX Slabs, EVO BO Coilovers Front and Rear, GenRight Rear Tire Carrier, RK Front lower Control Arms, Adams 1310 Front DS, LOD Sliders, DynoMax Comp Exhaust, EVO ProTek Skids, Fender Trim, EVO 1/4 Pounder and stinger, Warn 9.5ti, EVO C-Gussets, AEV Procal, Trektop NX
    ***Buy Jeep parts Made in the U.S.A.!!!***
  3. #3
    Nothing but a Thing pvanweelden's Avatar
    Join Date
    Apr 2013
    Location
    Des Moines
    Posts
    2,034
    What type of beadlock rim is it?
    Edit- doh didn't read the whole title :mad:
  4. #4
    Caught the Bug 4Low's Avatar
    Join Date
    Sep 2013
    Location
    Iowa
    Posts
    55
    ATX Slabs there is a good write up on the jeep tech section.
    Sent from my XT1030 using WAYALIFE mobile app
  5. #5
    Web Wheeler 10frank9's Avatar
    Join Date
    Mar 2012
    Location
    So Cal
    Posts
    13,210
    Here you go:
    http://wayalife.com/showthread.php?t=6979
    Video included. Hope that helps.
  6. #6
    Join Date
    Feb 2014
    Location
    SW Missouri
    Posts
    3
    There is an internal gap of about 1/4 inch. Is that ok?
  7. #7
    Join Date
    Sep 2013
    Location
    Iowa
    Posts
    55
    Quote Originally Posted by Tmac View Post
    please watch the video, there are several things in it that will help you and keep you safe.
  8. #8
    Been Around the Block
    Join Date
    Oct 2013
    Location
    United States
    Posts
    349
    Use a rubber mallet to get the bead on the rim. Then set your ring on and start the securing process. And like others have mentioned. Watch the video it does a great job as a tutorial.
  9. #9
    Join Date
    Feb 2014
    Location
    SW Missouri
    Posts
    3
    I watched the video, the bead on those nittos are not even half as thick as my Super Swampers. Being a super stiff tire doesn't help matters either.....
  10. #10
    Living the WAYALIFE MTG's Avatar
    Join Date
    Jan 2012
    Location
    Reno eNVy
    Posts
    13,638
    Maybe a picture would help us see what the issue is?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
