Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Need help with EVO bolt on coilovers.
  1. #1
    Hooked cuongdyna's Avatar
    Join Date
    May 2012
    Location
    Whittier
    Posts
    216
    I need to replace my upper springs on coilovers. I have to springs. I just need someone's help and tell me how to remove the springs. After I removed the coilovers from my jeep.
    Thanks
  2. #2
    Nothing but a Thing rubicrawl's Avatar
    Join Date
    Feb 2013
    Location
    valencia
    Posts
    1,468
    I'm thinking of doing the same what springs are you going with
  3. #3
    Join Date
    Jun 2012
    Location
    San Diego
    Posts
    83
    Quote Originally Posted by cuongdyna View Post
    I need to replace my upper springs on coilovers. I have to springs. I just need someone's help and tell me how to remove the springs. After I removed the coilovers from my jeep. Thanks
    Once you have the shock off you need to simply undo the pre-load and take the lower spring seat off. On the Kings you need some kind of tool to spread it with.
  4. #4
    Join Date
    May 2012
    Location
    Whittier
    Posts
    216
    Quote Originally Posted by rubicrawl View Post
    I have 200 now replacing with 250.
  5. #5
    Join Date
    Feb 2013
    Location
    valencia
    Posts
    1,468
    I think I might do the same
  6. #6
    Join Date
    May 2012
    Location
    Whittier
    Posts
    216
    Quote Originally Posted by mrmike View Post
    I should have put up this picture. My question should have been. After you remove the coilovers how do you remove the this to drop the springs.
    That the picture is of the rear. It was just an easier to take a picture but the fronts are the one that I'm replacing.
  7. #7
    Old Timer ttfhell's Avatar
    Join Date
    Dec 2012
    Location
    Fontana
    Posts
    2,517
    Push up on the coils to take pressure of the metal retainer and wiggle. There is no spreader tool.
  8. #8
    Join Date
    Feb 2013
    Location
    valencia
    Posts
    1,468
    Quote Originally Posted by ttfhell View Post
    You don't need a spreader tool? You do it all on your own hmmmm
  9. #9
    Fresh Catch
    Join Date
    Feb 2014
    Location
    Springfield, Ma
    Posts
    22
    The easiest way to take them off the vehicle is to jack it up from the frame until the load is completely taken off the shocks. Then unbolt them from the vehicle. The top of the coilover should have an adjusting nut that needs to be loosened to remove the pre-load on the springs. With the pre-load removed, the coils slide up enough for the bottom cup to lift up off the bottom of the shock and slide off the shaft. drop the springs off the bottom and replace the one you want to and reverse the removal process.
  10. #10
    Join Date
    Dec 2012
    Location
    Fontana
    Posts
    2,517
    This is tool I used both times. lolImageUploadedByWAYALIFE1392587521.997369.jpg
    If you take all the preload off it should be good. You can have someone push down on the coils if they are super tight while you wiggle.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
