Hello! ? About King 2.5" Bump stops
kevinp
Hello there!
So, I have a RK 2.5MT lift and Bilstein 5160s. I'm thinking about installing THESE BUMP STOPS. King's website shows them being used in conjunction with coils (opposed to coilovers). Is that the case?
Thank you!
Kevin
TheDuff
You can use them with coils, they go on the same spot the factory bump stop is now
Sent from my LG-D800 using WAYALIFE mobile app
ChaosNein
Oooops, looks like we need to update out pic on the website. Yes the bumps you are looking for will fit in your factory towers with minor trimming.
ChaosNein
no sir. they actually have some adjustability built into the can if need be.
the 2.5 actually refers to the amount of travel the bumps have and not the diameter of the bump itself
TheDuff
To expand on that, you still gotta add a bump stop extension, which bolts to the spring perch that is on the axle side like this: 1394901761149.jpg
Obviously you would want to use the size bump stop needed for your lift height.
Correct me if I'm wrong, but I believe they come with 2.5" bumpstops
ChaosNein
To expand on that, you still gotta add a bump stop extension, which bolts to the spring perch that is on the axle side like this: View attachment 73794
correct! this simply replaces the factory foam
kevinp
Yes, but it does up the eye candy quotient! :) And keeps it from bottoming out so hard. I'm going to order them (it'll be a couple of months. I have an Army-sponsored visit to another country to get through first).
Thanks for the info!
Kevin
