Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: EVO Rock Sliders
  1. #11
    Hooked leximann's Avatar
    Join Date
    Mar 2014
    Location
    Florida
    Posts
    204
    Since the finish is raw steel, I plan on spraying with Bedliner. What should I prime with & what's the best bedline product?
    Leximann
  2. #12
    Join Date
    Mar 2014
    Location
    Florida
    Posts
    204
    Quote Originally Posted by Rebel JK View Post
    To save time =$ you probly want to have layout and temp support figured ahead of time before taking it in. I would recomend pre mouning and using a few of these K5 self tappers thru rosette holes at hom
    Attachment 76388
    e first. Then remove for drive to shop then re mount. If welder is not going to have to worry about clamping this together it should save a bunch.
    These screws are designed gor 1/4+" steel and will go thru frame like butter
    Where could I find the tappers lol I've been to ace hardware and Home Depot, no luck
    Leximann
  3. #13
    Knows a Thing or Two aldaman's Avatar
    Join Date
    Oct 2012
    Location
    Hawaii
    Posts
    980
    Quote Originally Posted by leximann View Post
    Any auto parts store may carry them....
  4. #14
    Join Date
    Feb 2013
    Location
    North Richland Hills, Texas
    Posts
    5,716
    Try looking at home depot back in the metal roofing area. That is where they can be found. I have about 200 of them in the garage from doing my roof.
    R/
    Will
  5. #15
    Fresh Catch tennesseegator's Avatar
    Join Date
    Nov 2013
    Location
    East Tennessee
    Posts
    21
    Several coats of self-etching primer. and rustoleum bedliner spray has worked best for me.
  6. #16
    Hooked BBrown626's Avatar
    Join Date
    Mar 2012
    Location
    San Diego, CA
    Posts
    188
    Quote Originally Posted by tennesseegator View Post
    Finish like he said ^^
    I don't see why you would use sheet metal screws. You will then have to blindly weld in the holes you made in the frame. Use a couple C-clamps and jack stands to hold them in place. Tack weld and then let the sparks fly after your sure they are where you want them.
    Even if your not the best welder your likely securing them better than something like those flexible rails that bolt to the body mounts.
    The EVO rails are great! I just took mine through the Rubicon this week. My brother in-law went with me and he has Ace. We are on 35's so we bounced our way through and a few times we had to pivot off the rocks with our rails. Both made it through without damage, but the Ace rails visibly flexed quite a bit and made me a bit nervous.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
