Spring question!
Devallee
Putting on plush rides. This fell off of the top of the spring when I took the old ones off. The old springs are part of the rubicon express lift I have on the jeep. Question is... is this supposed to be there? Or did it come with the lift I have on there? Do I keep it on there or leave it off?
Sent from my Galaxy S37
Landman
I believe it's just an isolator. I've got mine on especially on the rear. Not sure it matters of you wanna keep it on or not.
rcdude3
Leave it in. If you remove it, you may get a metal on metal squeak/grind from the contact of the spring and the top spring perch.
wwood
That is the factory spring isolator. Should be one on both front and rear springs. Acts as a spacer and prevents metal to metal contact and noise at the body end. Definitely leave it in.
